CatfishJim1
Thread starter- Joined
- Jul 29, 2001
- 4
I have a johnson120 1987 v-4 that has no power and will not plane out the boat and the motor will bog and die if you try, it idles rough and there is an alarm that has gone off two short beeps followed by two long beeps(does not happen all the time). The VRO has been disconnected and here is a list of things i have done.<br /><br />new gas, new tank<br />compression between 115-125 <br />spark on all plugs<br />new plugs<br />checked fuel filter <br />pumped bulb while running<br />new impeller<br /><br />The pecular thing is that every once in a while the boat acts like nothing is wrong and takes off like a bat out of hell, it will run that way for a while and then return to its normal slump. I know this could be a lot of things if someone could help me narrow it down, i'd be grateful. THANKS<br /><br /><br /><br />------------------<br />Everyday a Catfish is just around the way maybe tomorrow a big one will take my worm away
