Power loss at high rpm Mercury 15hp 1990
Dutchdude
Hi,<br /><br />Just bought this outboard, runs fine the first time, but the second time it started to run rough at full throttle. At Low and midrange speed the engine runs fine.<br />- Bought new sparkplugs, no result, :( <br />- Mercury Dealer cleaned the carb. en placed a new fuelpump, no resul, :mad: <br />- Checked the ignition timming at low and high speed, ok, :) <br />- Bought the repair manual and checked the Low speed charge coil (3150 Ohm) and high speed charge coil (133 Ohm). The high speed charge coil should be between 200-250 Ohm.<br />And now?? buy a new charge coil?? :confused: <br />Give me some advise please..<br /><br />Greatings,<br />Dutchdude<br />p.s. Sorry for the language, i'm really Dutch :)
roscoe
Re: Power loss at high rpm Mercury 15hp 1990
You are not Dutch here.<br />You are a boater!!!<br /><br />Sorry for what language??<br /><br />I am no expert on ignitions, but you seem to have found the problem. I hope a new high speed coil solves the problem. <br /><br />Also, it helps to curse a bit when working on an engine. :)
