Power loading
tyofwa
OK... explain this power-loading thing to me.<br /><br />When I load, I usually center-up, motor toward my trailer at idle-but-in-gear speed, about 20' from the ramp I will drop into neutral, and trim up the OB, just leaving low enough to offer me some last-minute steering corrections. From there, I will attach the strap, and winch up until the chain can get on the eyelet. <br /><br />Sometimes, the angle of the trailer requires me to come in a bit faster, or re-engage the engine ( in the higher trim position ) for a second to get high enough on the bunks to reach the strap. <br /><br />So.. Am I one of the folks dredging the ramp? This approach seems better suited than hopping in the water with a line and trying to guide a boat drifting in the slough current where the launch is at.
heyttown
Re: Power loading
That isnt to bad, it still may wash out some of the ramp, Ive seen idiots drive it on the bunks, then when forward motion stops , nail it....... trying to get the boat all the way to the bowstop, now that will do alot a damage, I have actually watch a guy drive his boat crooked on the bunks and go past his bow stop by almost 1 ft, as he almost fell out of the boat................I normally idle till forward progress has stopped, by then I am usually 2 or 3 ft away and can hook the boat, and crank it up.
wikelam
Re: Power loading
I get lined up and just idle on. then use the winch to get it the rest of the way.<br /><br />I do not use motor to get it on the trailer, but i am grateful that others do. this will create a wash at the end of the ramp after time. this is an excellent hole for a big cat to hold up in. have pulled a few big cats from under ramps before.<br /><br />I would not advise it though. have seen one idiot dent his tailgate of his truck from getting the boat angled on the trailer and throttling it.
D
DJ
Guest
Re: Power loading
I Guess I'm an idiot. I've never used more than two feet of my winch straps.<br /><br />If your trailer is set up correctly and you are in deep enough, the great blasts of propeller thrust aren't needed.<br /><br />In and out in less than one minute.
JB
Re: Power loading
I think this belongs in Boats.
