Power head swap from 4cylinder to 3 cylinder
jgarlock92
Hello,
I have a 72 (I believe) 65hp Evinrude triumph with a lot of lower unit issues.
My friend just blew the power head on his 69 starlight that has a manual lower unit that he just rebuilt.
Would It be possible to take my power head and put it on his lower unit?
jimmbo
Welcome to iboats.
No
Crankshaft/Driveshaft Splines are different, and even if they were the same, the Gear Ratios are no where close to each other
Agreed---No chance it will fit.----Are you sure your friend has a 69 V-4 with a manual shift lower unit ?
jgarlock92
That's what he has told me, I asked him to send me the model number so I can look into it further. I know for certain it's a 4 cylinder.
I think splines are the same.----I do not believe there was a manual shift V-4 marketed in 1969.----Post the model # here.
jgarlock92
Hello,
Update, it's apparently a 1960 model 50523-16847
Doesn't sound like it'll work unfortunately.
Does anyone know where to get decent parts for the old hydro-electric shift?
No surprise that it was not a 69 model.----If in Canada----evinrudeparts.ca----May be able to help you.
