Mark42
- Oct 8, 2003
- 9,334
In the fall of '05 I remounted the powerhead on my 40hp. The bolts that were used were not stainless and the heads had rusted from exposure to the salt. I cleaned up the bolts on a wire wheel, sprayed some Rustolium on the heads and re-installed them with a dab of anti-seize on the threads.<br /><br />I am wondering if I should replace those bolts with the stainless steel bolts offered in the powerhead bolt kits. I don't mind taking the time and the expense is low. I'm more concerned about making sure the threads in the powerhead don't get galled or messed up from using the wrong hardware. <br /><br />Thanks,<br />Mark
