Pounds of torque for head gasket?
mmaddox
I have a Johnson 1969 40-hp electrostart outboard motor and am putting a new headgasket on it. How many pounds of torque do I need to apply?
Skyhigh
Re: Pounds of torque for head gasket?
The manual reads 228 in./Lbs (not ft./lbs)
ob
That translates to 18-20 ft.lbs.
mmaddox
Thank you very much!!!
mmaddox
Does it matter what order I tighten the bolts in (clockwise, counterclockwise, opposite sides)?
Skyhigh
1 side top 1 side bottom and so on....
ob
It sure does.Most repair manuals will provide the actual sequence .It basically starts from the center of the head cover and works its way out to the ends in an ironing pattern.Something like this.<br /><br />13--14<br />9 --10<br />5 -- 6<br />1 -- 2<br />3 -- 4<br />7 -- 8<br />11--12
mmaddox
I wonder if my torque wrench is registering properly because it does not seem I'm applying much pressure at all before it clicks letting me know I've applied enough. Is 20lbs barely more than hand tightened?<br /><br />Also, I'm a little confused by the response on tightening sequence.<br /><br />If I had the layout:<br />_0_1_<br />2___3<br />_4_5_<br />6___7<br />_8_9_<br /><br />It sounds like Skyhigh was saying I would tighten 4-5, 2-7, 0-9, 1-8, 3-6.<br /><br />It sounds like ob was saying I would tighten 4-5, 2-3, 6-7, 0-1, 8-9.<br /><br />Which of the two above is correct?
wilde1j
mmaddox, ob has it right (start with 1, 2, etc.). Heads are tightened from the inner most machine screws and moving outward, in a staggered fashion. Also, it's normally recommended that the tightening process be done in two or more passes, i.e. start at 10 ft-lbs, then in a second pass set the wrench for 20 ft-lbs. The idea is to tighten all evenly and gradually.
mmaddox
Thanks everyone! You guys are an awesome help.
