possible lowers for 1983 150 crossflow
Benny1963
i see were the lowers from the large v4s will bolt to the v6s
is this a straight bolt over as long as the shaft is the same length
and will the shift rods work .also how will it stand up behind the 150 175
i can get several of these cheap need to know what years to look for
i guess iwill have to reprop . i will buy a gearcase for a 150 and have my 150
stuff swapped to new case and then go back to it .
any help with this would be great
thanks bennyb
Faztbullet
Re: possible lowers for 1983 150 crossflow
The V-4s are different gear ratio than V-6's. Makes a good drag boat ratio for a lite boat. Also there is 2 different driveshafts: 60 & 90 degree engines. What kind of case ya need??
Benny1963
mine is a 150 1983 crossflow
thanks bullett im going fishing this morning may call you around 6 or so
Bennyb
