Possible lower unit leak 1960 18 hp Evinrude fastwin
Eoghan
New to Iboats. Have been reading a lot of the old treads and have taking a lot from them. Recently bought an Aluma Craft with the 60 Evinrude. I have got the motor running (in a tank) after cranking it several times. Seems to be running pretty well. Still playing with the slow and fast needles to find where it runs best. After running it for a while I've noticed some oil in the water and around the lower unit?? Possible a leak. I also have a pin size hole on the inside of the shaft that spits out a constant stream of water when the motor is running. When I stop the motor it turns into a creamy milky liquid seeping out. The water mixing with some oil creating this?? Is the hole meant to be there? I want to take the boat on the water and test it but am hesitant with these issues. Bad gasket and seal in the lower unit? Tough job to replace it? Can post some pics if that will help. Any help or advice would be great. Thanks in advance.
F_R
Honorary Supreme Mariner
What you are observing is totally normal. That's just the way it is. Gear oil leak?? Well I can't answer that one because I don't know if it is leaking or not. But I can assure you it isn't leaking so badly as to cause the mess you are looking at.
Now, for the pin hole: Please tell us more on that. It doesn't sound like anything I recognize. But there are numerous drain holes that do what you describe. Picture??
Many new owners are confused by this foamy oil / water mix on older motors.-----If you are worried ( $$$$ ) about a lower unit leak than hurry to your local repair shop to have the lower unit pressure tested.---And yes there are drain holes on the lower units to get rid of trapped water.
Eoghan
Due to what I gave for the boat I am not going to take it to a shop. Don't want to pay more than I paid for boat/ trailer/ motor to have someone look at it. My concern is the salt water may getting into the gear case and destroy the gears, if the seal is not good. It is a motor that has sat up for quite some time. I am going to work on posting pic F-R to give you lads a better idea. It may just be a drain hole. Ive just read a lot about the milky color fluid being bad news
Thanks for the input
Milky fluid INSIDE the gearcase is bad news.---Milky / foamy liquid leaking from the exhaust housing is normal.---These two things are not to be confused !!!----And lower units have drain holes in them to prevent freeze damage in colder climates.
F_R
Gear oil can be changed if it is contaminated. In fact the owners manual says to do exactly that even when it was new. When the leak becomes excessive---THAT is the time to consider a re-seal job.
Eoghan
F R I am going to change the gear oil for sure. That will tell me whether there is a lot of water mixing with the oil or not by looking at the old oil. Fingers crossed. Want to get this bad boy on the water
