troutmaster1972
- Aug 24, 2009
- 28
Ok thanks in advance for any help Heres the story 1997 Johnson 70 hp motor has had 3 powerpacks blown and replaced by the shop Finally after the last one they replaced, said enough is enough, you are not solving the problem and are totally done with them Decided to try to figure it out myself. Ohm checked the coils and stator as good, the rectifier is running the tach and charging the battery. What I did check almost as an afterthought was the continuity of the spark plug wires Only one of the 3 had continuity My question is would 2 bad spark leads cause the power pack to blow? When it does it actually bubbles the surface of the powerpack. I have my doubts something this simple would cause it but wanted to find out from you all Thanks again for your time
