99 Glastron 5.0Gl Volvo Penta / SX Outdrive only 100hrs on it!!!
Well Ive tried to track down this damne rattle noise from the back side of the engine and havent been able to figure anything out. The u-joints are good, the gimble bearing is good and outdrive is smooth. So I think maybe the coupler and do a search and find this thread:
http://forums.iboats.com/showthread.php?t=314470&highlight=penta+coupler
IDENTICAL symptoms as mine to a T so I figure I may have a head gasket issue. There is NO water in the oil but the last time I pulled it out of the lake I noticed when pulling the plug the water had a "rainbow tint" to it which I thought was odd. So im checking things out running it in the driveway on the muffs and loosen one side of the y clamps for the exhaust and notice water is flowing through there!?!?!? how can water be coming out the exhaust but not getting in the oil??? Could this possible be my problem?
little more info from my last outing...While trying to troubleshoot the rattle noise I came to a pretty abrupt stop after going about 35mph, after which the boat would not start and barely turned over leaving me stranded for about 20 mins. Smoke was coming from the carb?!?!? and after 20 mins of cranking occaisonally the boat started and I limped it back on the trailer, after which I started it on the trailer in the water and it ran perfect. After reading about exhaust flappers and mine being gone (found both and hinge pins when I pulled outdrive to check things out / grease things) I think the water may have got pushed back into the exhaust and maybe cranking it over blew the gasket?!?!? Got it home ran it on the muffs and again ran perfrect, idled perfect and run good through the gears in the drive....
