Posi-lock connectors
llfish
Has anyone used these connectors and what do you think of them.
llfish
Re: Posi-lock connectors
They are used to connect wires together. Rather than crimping the connectors on to the wires they screw together.
Richard Petersen
OK. I do not know of any screw compression connectors that are made to have fresh or salt moisture get at them. They are normally not for marine use.
18rabbit
They look good to me but as Richard points out I doubt if they would be a good choice for a marine environment. Posi-Lock might work if you were to put a dab of silicone sealer in there behind the wire. However, if you look at that website you’ll also see a product called Posi-Tite. That critter looks like it is what you need but it only comes in AWG 22-18, not AWG 16. MSRP for the Posi-Lock is $30/50 pieces for AWG 16. I noticed on their web site they mention Wal Mart as a retailer, should be less expensive there.<br /><br />Thanks for the info, Grumpy. I’ll look into these connectors some more. I like the idea.
llfish
I bought a couple at an auto parts store. They are starting to show up everywhere. They really hole. Tried pullling one apart and the wire broke. I think I will try one and put a shrink tube over it.<br /><br />Thanks for the Information!
llfish
Caulk will destroy the wires. I am not sure why. But it will!!!!!<br /><br />Thanks for the Information!
Richard Petersen
To all lovers of Silicone rubber sealant. NEVER put it on exposed copper wire to stop corrosion. IT CAUSES corrosion due to the vinager smell. The vinegar smell is really Acetic Acid and it is known to cause the "Black Death" in all copper wires. The copper starts turning black and becomes brittle and intermittant. Once it starts , for some reason it will keep corroding after the Silicone cures. DON"T put it on copper wires to help them. It will destroy them.
18rabbit
Yeah, kinda. Mil-spec requires all copper conductors housed in silicon insulators to be coated with silver. Silicon insulators are highly desirable for their increased flexibility, abrasion resistance, shape retention (no memory), they withstand higher heat, and ability to handle environmental factors that lead to aging (hardening/cracking) of the insulator. The silver coating that is bound to the copper conductor acts as a barrier to prevent the corrosion you speak of.<br /><br />Somewhere around here I have the details of that ‘vinegar’ smell that is in most silicon products. It is chemistry used in the manufacture of silicon and is left in the product to keep silicon in a ‘jelly’ state so it can be applied. That chemistry evaporates out. After set, supposedly the ‘vinegar’ chemical is gone and silicon is inert. Fwiw, silicon used in medical applications is not manufactured using the same chemistry because that chemical is a hyper-allergenic for some people.<br /><br />I wouldn’t worry about a dab of silicon penetrating the polymers of the typical insulator on marine wire but you definitely don’t want it on the copper conduct. On the other hand, I don’t know how long it takes for silicon to fully set (off gas). I don’t think my suggestion is good idea after all because the Posi-Lock encloses the exposed conductor to any residual off-gassing inside the connector. I’m not sure about the effects of the gas on the tin coating...there must be a reason mil-spec requires the use of the more expensive silver coating.
