Davem3
- May 15, 2011
- 542
Last Sunday when Josh and I went out , we took a couple of dozen shiners with us to see how we would do with them...........two Rainbow Trout and a Smallmouth Bass later, all within a span of 20 minutes and I was like H**l to the yes.
Only one tiny problem remained............... I had bought a shiner bucket to get me through the day, but they were mostly dead inside a hour, and it is not even hot up here yet...............
So, on to Plan "B" we went............ after scouring the forums this morning, ( i have the day off and it is pouring outside), i finally found what i think will be a suitable fix for the situation ..........
I have this old 16 Quart cooler i no longer use at all, it used to go with me in my truck every day for drinks and lunch, but finally got too grungy for me to even contemplate using it any longer, PERFECT!.
So, round and round we went and got the following items .............
one POS cooler, LOL
one Attwood Tsunami T800 880 GPH Cartridge Livewell Aerator Pump
2 feet of hose clear, so i can see what is going on
Aerator Spray Head, Black - T-H Marine Supply
one 3/4 elbow, so there will be no kinks in the line
4 clamps
3M 5200 sealer
1" drill bit ............ and my Makita cordless drill
some electrical line to extend the wire, with a inline fuse of course!
and finally , a Livewell Pump Debris Strainer............
clean the cooler :facepalm: first????
drill the 1" hole near the top for the spray head and attach it using rubber washers, and 5200 it into place.........
now for the inlet, filtered side..................
measure 1 1/4" up from the bottom ON THE inside of the cooler and using a pilot drill (1/8" is fine) drill from inside to the outside............
now go back to the 1" drill bit and drill it in.............
clean out the cooler, and install the pump, using rubber washers and 5200 again..............
connect the plumbing, connect the extension wire, ( they only give you a 29" lead, what a joke) and connect your inline fuse to the positive side............
WAIT 24 hours first to let the sealer do it's magic, and stop any leaks that could happen ............
add ice, 10 quarts of water , and presto.............
FINISHED!!!!!!!
one POS cooler, LOL
4 clamps
3M 5200 sealer
FINISHED!!!!!!!
