Hey everyone,
I?m contemplating different cooling ideas for my 26 foot older sea ray sundancer (1985). I?m trying to do it with the most minimal $$ as possible and came across the portable air conditioners that they have out these days: http://www.walmart.com/catalog/product.do?product_id=5402975
This product looked interesting because:
1. It can sit inside of the boat as it doesn?t drip water and the exhaust hose can just be put up to a window.
2. It?s cheaper than the cruisair carry on marine a/c units and doesn?t hang into a hatch.
3. My other option was to get a house window a/c unit and make a cover on it so that it pipes the air into the hatch (once again, this one wouldn?t require me to pipe the air in through the hatch).
At $300, it?s only like $200 more than a cheap window unit.. and is way less than a cruisair carry on.
It?s 7000 btu and I looked at the power ratings in comparison to a window unit a/c at 5250 btu
Portable a/c 7000btu:
Voltage ? 115V
Amps Cooling ? 8 (doesn?t say what the start up amps are)
Watts Cooling - 900
General Electric 5250btu window unit:
Voltage ?
Amps cooling ? 115v
Amps cooling ? 4.6
Watts cooling ? 490
Are these figures very close? What size generator would be required to run the portable a/c? I believe the 5250 btu could be run with a Honda EU2000i?
From what I?ve read, the portable a/c units don?t cool as efficiently as the portable units, but I feel that you are going to lose efficiency on a window unit by piping it in through a hatch, so I?d probably feel that the 5000 btu window unit and 7000 portable unit would cool about the same..
Just looking for alternatives (inexpensive alternatives) to mounting an a/c unit in the hatch.
Let me know your opinions....
Voltage ? 115V
Watts Cooling - 900
Voltage ?
Amps cooling ? 115v
Amps cooling ? 4.6
Watts cooling ? 490
