While changing the Poppit valve in my Yamaha 250 ox66, I managed to push the old rubber gromet into the cavity beneath the poppit. Any suggestions on how to retrieve it without taking apart the whole back side of the engine? WIll this cause problems if left. I did start the engine and run it. It did produce about 12 PSI water pressure on plane. Before the replacement I did not get more than 5 PSI, and had low RPM temp alarm. Now, no alarm. Seems to have fixed my problem, but did I create another?
