Poppet Valve
MichaeltMoir
Hi
I read in a couple of threads when they refer to the poppet valve, what is it function and will a Yamaha 130 have one? if so where is it located?
Thanks for your help
Mike
JUSTINTIME
Re: Poppet Valve
relies pressure at higher rpms
ur 130 should have one
look it up on yami's site under cylinder crankcase
Ray Neudecker
Re: Poppet Valve
Most models it is located at the rear near the bottom of the powerhead. It will have a large hose attached.
MichaeltMoir
Re: Poppet Valve
Thanks for the info, could it ever possible fail and what would the symptoms be if it did?
Thanks for the help so far
Ray Neudecker
Re: Poppet Valve
It can get clogged and not seal properly resuting in low water pressure.
