Re: POPPET VALVE QUESTION
R-fish, maybe I'm out of line, here---don't mean to be---but I'm not sure if you caught what dilligaf was saying. Water flows from inside the block, through the poppet, and UP the hose that goes to the top of the motor, where it dumps into the exhaust. <br /><br />The hose is not the inlet TO the poppet, it is the outlet FROM the poppet. The poppet releases water from inside the motor block when the water pump is providing more cooling water than can flow through the thermostats, which is at higher rpms, of course.<br /><br />If you can detatch that hose and blow through the poppet, it is either stuck open or has a damaged diaphragm. I've only worked on one boat motor, my 135, but I don't recall seeing anything staked in, as far as the poppet goes. Maybe yours is different. But, when you take the plate off, the poppet assembly should come right out of the side of the block. I get the impression yours is being stubborn about coming out. Maybe just needs a little "persuasion"??<br /><br />Hope that helps.<br /><br />-dd-
