Originally posted by Hunter Fabrication:<br /> 75 Glastron CV-16 16 ft 115 Johnson 30 MPH max even fully trimed with the power tilt. Recent carb rebuild new coils wires power pack plugs and water pump What else could be wrong? Yes I have a book for it.
Thanks for the reply! the boat is a 1975 glasstron carlson cv-16 the tach is not working at the moment so unsure about the RPM sounds like it is turning pretty tight will check on plate today! The lady I got it from said it would do 45 mph shes got the ticket to prove it.the prop is the factory 3 bladed alum prop.I am going to get the book out and check the timing and look at the carbs again I rebuit the carbs myself they were way easier to do than the carters on my 440.Originally posted by Hunter Fabrication:<br /> 75 Glastron CV-16 16 ft 115 Johnson 30 MPH max even fully trimed with the power tilt. Recent carb rebuild new coils wires power pack plugs and water pump What else could be wrong? Yes I have a book for it.
