FurFinFeatherFun
- Jun 1, 2003
- 3
Experiencing poor high speed performance (about 1/2 speed) on my 1957 35HP Evinrude Big Twin. I just replaced both coils, points (set to .020), condensers, plugs J4C (set to .030). I couldn't find new plug wires although the old ones look "sort of" OK. Rebuilt the carb (noticed the high speed needle is blunt and doesn't come to a point like the idle mixture screw). I don't know if that's a concern or not because it looks like it was machined that way and not worn away. I'm running 32:1 gas/oil ratio. It idles and starts well. I get NO control of high speed while adjusting the high-speed needle. It runs the same with the needle completely closed or turned WAY out. The throttle is opening all the way and is not binding, The choke is also open all the way and is not binding. I'm running the old style pressure tank and am thinking about changing to a fuel pump. I'm not sure what pressure the tank is holding but it does hold quite a bit of pressure for a long time (days). I'm also looking for a generator but don't want to dump any more money into it until I get it running well. I already have the wiring for the generator. I just need the generator, belt and possibly mounting bracket. I am also getting either a miss or jumping in and out of gear while running wide open. The engine doesn't appear to rev during the "jumps" so I'm hoping it's just a miss. I'll worry about that more once I get full power restored if it's still there. I checked for play in the shift rod and have NONE. I have the 2 piece rod with the "inspection window". Compression in both cylinders is almost right on at 120psi each. Fuel filter is clean. I also checked synchronization and it appears to be right on. The pointer on the manifold is right on the flywheel mark just as the throttle begins to move. When I first ran it about a year ago I had full throttle and it ran great for about 15 minutes. It then bogged down and I haven't been able to get the power back since then. I also replaced the water pump before my first run, just as a precaution, and I get loads of water out the exhaust. The water pump was the only maintenance performed prior to my first run. All other parts were replaced after I lost power. Inspection of the plugs on several occasions shows a rich mixture. They are wet and dark but have no fouling deposits. I haven't inspected the reed valves and I'm not sure if that would affect high speed performance only or not. I guess my root questions are:<br />1). Should the high-speed needle be blunt or pointed? If pointed, where can I get a new one?<br />2). Could the pressure tank be holding too much pressure and could it cause the engine to run rich?<br />3). Where can I get a generator (once the engine runs well)?<br />4). Would it be worth replacing the pressure tank with a fuel pump and if so, where can I get a conversion kit i.e. new tank & pump?<br />5). Where can I get plug wires? I tried a few dealers & none of them have them.<br />6). Could the reed valves cause poor high speed performance even though the engine starts & idles fine?
