TrenchFisherman
- Apr 7, 2002
- 223
Just got a used pontoon this year and have really been enjoying it but have had some issues as well. I believe my boat has a ventilation problem because at times I can drive along and it will be running fine and then with a wind change or start going over larger waves the boat will start to over rev and then I will have to back off until the prop can get grip again. The reason why I think it is ventilation rather than cavitation is because I do not see my cavitation plate while on plane which i know is a problem but also because the prop has pock marks all over the face of the blades. I went to a few prop websites and used there prop finder tool and they said I should be using a 14 or 15. Well I went down to the dock and looked at my prop and I have this prop, 4877342A4515P, which is already a 15 inch so now I am not sure if a larger prop is even possible. It is a 2003 Mercury 90hp 2 stroke engine on a 23 foot pontoon boat. If you guys have any advice that would be great!
