Re: Pontoon Boats
Namron,<br /><br />I assume that you are talking about the tube. Foam filled VS. Air filled. Frist, the air filled tubes are not pressurized. They will hold air, and adding pressure is just to check for leaks. <br /><br />Now to answer foam vs air. If you go with a foam filled tube and you get a leak, you are in a bad place. There is no way to dry the foam out and you will always have wet foam. That will cause things like a list, performace issues, and trailer weight. If you have an air filled tube and you get a leak, you drain the tube, take the boat to your local welder and fix the leak. You are done.<br /><br />I would only do an air filled tube.
