Poly Tank Replacement v-bottom under deck
Brusea
I have a 1978 Robalo 18 CC that I just pulled the rotted 30 gal Aluminum tank out of and would like to have a custom Poly Tank made to replace it. Does anyone know where I can have this done?<br />Dimensions are 38" X 23" X 8" "V" bottom. Any help would be appreciated. blytle@comcast.net
Reel Poor
Re: Poly Tank Replacement v-bottom under deck
You might give Tempo Products a call to see if they offer something that may fit.<br /><br />Thats not a very big tank is it? What about 18/20 gallons.<br /><br />Tempo Products Company Inc.<br />6200 Cochran Drive<br />Solon, Ohio 44139<br />Tel: 800/321-6301<br />tempoproducts dot com
WillyBWright
I'm not aware of any custom Poly tank makers. It requires a mold and it takes a lot to make one ... far too much to make jsut one tank. Your only hope for that is if somebody already makes one that would fit. Otherwise, aluminum tanks are a lot easier to fabricate requiring mostly bending and welding.
Brusea
Thanks for the replies. It's a 30 gal tank the height measure is 9", not 8" like I posted. I've found a Tempo polys that is close, 43" 29 gal, but that means I'll have to cut out the "tub" it sits in. The original maker of the tank is still in business and can make a replacement Aluminum for about $350 delivered, but I was hoping to go poly. Thanks, Bruce.
