Points etc. for distributor; I have a dist with a number stamped onto it #0-231178019
BA'sboat
I can find points, cond, cap but they say there for a dist with the last numbers ending in 7 instead of a 9, everything else is the same. it is for a
1986 AQ131A 4 cly Bayliner capri, with a 275-OD, the dist is also stamped Germany . what am I looking at and do I have any options?? thanks in advance
BA
Don S
Re: Points etc. for distributor; I have a dist with a number stamped onto it #0-23117
Your best bet is to first get the OEM part numbers for your engine.
Here is the page for the distributor for an AQ131A engine.
http://www.volvopentastore.com/Dist...*****.776739936--store_id.366--view_id.782406
Now, when you look at aftermarket part you can make sure they cross to the proper OEM Numbers
Here is the iboats link to the OEM and aftermarket parts so you can look things up.
http://www.iboats.com/Volvo-Penta-Parts/dm/*******.433278441--**********.472308670--view_id.352668
BA'sboat
That is the beat information I have gotten, thanks again Don, Have a happy holiday, I can't thank you enough. BA
BA'sboat
That is the best information I have gotten, thanks Don you are the man, have a happy holiday,BA
