Re: POINTS AND PLUG SETTINGS
I had the same thing happen a couple years ago. It was an unusually large peice of kelp. I had replaced the impeller about 2 weeks before.<br /><br />The condensors are seldom a problem, and easily tested by swapping them. If it doesn't kill spark on the bottom cylinder, it must be good. Try cleaning and regapping the points. If spark doesn't return, and the plug wires are good, then the coil is almost definitely the problem. You can try swapping it too if you want.<br /><br />Also, it's possible some of the wiring contacted the flywheel and the insulation got rubbed off. It needs to be tucked in really well.<br /><br />I hope some of that helps you out!
