Point me out the air/fuel mixture screw please.
Whistler123
Hello.
Struggling with cutting out at low speeds and struggling to get out the hole. Once its going it is fine.
Lookong at changing my air/fuel mixture as i think it might be lean.
I already checked for fuel line for cracks etc.
Cheers
jimmbo
red arrows, top carb has one too. Dirt/Gum/Varnish in the carb quite likely
Whistler123
Thanks bud. If you get anymore free time can you see the drain screw in that photo. Been told to drain them too remove gunk.
I am a newb but appreciate everything.
ondarvr
If there's gunk in the carbs and it's not running right you will probably need to clean them.
