hullofalottatrouble
- Jul 16, 2005
- 306
merc 260 with qjet carb petronix II and flamethrower coil.
got it to fire up and idle at 700.. got timing set a 8 btdc at idle speed in the driveway after warmed up to normal operating temp..
so its running and seems to have a miss here or there maybe? i dont really know.. but i pulled the plug wire on #1 and it died.. fired it up again and pulled #3 and it died.. fired it up again and pulled 5,7,2,4 and it really didnt seem to have any impact at all.. pulled 6,8 and there was some hesitation.. i pulled the 5 plug out itself and it looks like its been firing.. not fouled or anything.. looks good just like #1... its too dark and late here to do much more so ill need to give em all a look again tomorrow.. i put the timing light on the #5 and it appeared to be getting spark down the wire.. when idling..
so i guess my question is how should the engine respond when i pull a plug wire? should it die like 1,3 or be hard to tell? i had expected it to keep running but that i might hear a decrease in rpms?
compression is 150 all around..
its a muggy wet day today and had a small bit of white smoke out the prop when idling.. it came out about 8 inches then disappeared.. there was more at higher RPMS thou and it smells a bit like gas.. engine doesnt hesitate or anything when revving it up a bit..
it fires up fine.. idles fine. but something seems off?
also no signs of water in the oil or in the cylinders or on the plugs.. but i need to check that again when its lighter out..
