Re: Plugs for a 1967 Johnson 40hp
Depends on what you're doing with the boat...running WOT, cruising or trolling. The main difference between the J4C through J8C plugs is heat range...4 is coldest of the three, 8 is the hottest. Some people run a hotter plug when trolling (slow moving) to help keep the plugs from fouling. Whatever you choose, keep an extra set handy in the boat at all times. The stock plug for your outboard when new was the J4J, still available as the J4C, according to my chart for big twins between 1956-1970. Even the big Starflite 75 hp motors ran the J4J plug. Which reminds me...I need to check and probably replace plugs in both my big twins this spring.
