Re: Plugging Baitwell Exhaust
Excuse my ignorance, but by "baitwell exhaust" you mean drain?
But, you said you had "drain plugs out the back". Do you think your "drain plugs out the back" are actually intake holes? If so, than your "baitwell exhaust" is the baitwell drain, right?
My baitwell has a water intake (from a hose connected thru the transom, transom hole covered by a screen, with a sea-**** inside at the transom) and a drain (attached to a hose which drains out the side, UNDER the waterline -which I hate, no sea ****, no screen). I assume your exhaust/drain hole is below the waterline, right?
Do you have access to this leaky hose (whatever it's called) as in comes in thru your hull? If so does it have a sea-**** at the hull fitting on the inside? (a valve with a straight handle - turn it 90 degrees to shut it)
Intake holes under the waterline usually are covered by a screen of some sort. Drain holes have no screen. If your hole doesn't have a screen, it's probably a drain. Drain thru-hull fittings usually don't have a sea-****.
If you have access to the thru-hull exhaust/drain hole area from the inside, maybe you can install a shutoff valve right next to the hull. Home Depot has these which can slip into hoses and secure via pipe clamps. Shut it when not using the baitwell.
I suspect you have no access, so, for a plug, what about one of those rubber plugs that expand when you flip its little lever, or swell when you tighten the handle? The twist to tighten handles would probably work better, as there would be less chance of the moving water to rip it out as you cruise along.
Like the first couple on this page...
http://www.iboats.com/Boat_Drain_Plugs/dm/*******.648008165--**********.389875784--view_id.257673
At any rate, your could try it, and see if it stops your leak.
(Or, while your boat is on its trailer/lift, stick a garden hose in it, fill the bilge, and see if it leaks OUT of your exhaust/drain hole)
Sorry for the long post, but pics might have helped, and at least it shows I was thinking about your problem!
Jim
