Re: plug not firing
The 3 basics required are Spark, Fuel, Compression.
If you have the other cylinders firing, then the motor has spark. If that plug has no spark it will not fire. Cause? Bad plug, bad plug wire, bad socket in the disrtributor cap.
Other cyliders firing, so the motor is getting fuel. Is that cylider getting fuel? We don't know. Is the plug wet or dry? If the plug is dry time to pull the valve cover and inspect for valve opening.
If the plug is good and has spark and is wet (gas, not water), then time to check compression.
