Plug analysis?
nola mike
Went to winterize the 4.3 last weekend. Decided to check plugs while in there. Kind of strange. Overall ok I think, but #3 had me concerned. Looks steam cleaned on 1 side, and had specks on the electrode. Worried about pre detonation but thinking more likely salt deposits. They didn't seem to be ferrous fwiw, though a tiny amount. Compression was 135-152 on a cold engine, #3 was 147. Thoughts? Planning on borescoping and getting an oil analysis, looking forward to the oil analysis (block had at least 200k when I got it and has probably 500 hours on it during its new life), running T4 15w40 since I got it.
IMG20261109113256.jpgIMG20261109113311.jpgIMG20261109113334.jpgIMG20261109113421.jpgIMG20261109113434.jpgIMG20261109113523.jpgIMG20261109113604.jpgIMG20261109113857.jpg
alldodge
Maybe a bit lean, but don't see enough to worry right now. If boat will run hard for a few minutes, slow and stop without long idle than recheck that plug would provide better insight
Scott06
Agreed look very similar to the plugs out of my 5.0 vortec wouldnt sweat it although oil analysis wont hurt
nola mike
Thanks for the reassurance. It was more the ground electrode appearance that looked different from the others. The deposits on there (what are they?), the gouges out of the electrode, and that silverish color that isn't on the other 5 (see last 3 pics). At @alldodge , I still have burns on my arm from trying to do a plug chop when initially tuning the carb. Not a lot of room in there.
Chris1956
Honorary Supreme Mariner
Replace them. The deposits indicate that it is time. I do not think they are steam cleaned.
Lou C
I'd say they look a bit lean as well, are you sure there's no water getting in via the exhaust? You gotta get one of those cameras I like so much lol. Makes it quick and easy to find out. You can check the cylinders, on an OMC/Volvo elbow you can remove the top plug that's for a temp sensor, and get a nice view inside, takes like 5 min per side. Not sure if you can do the same on Merc but you could if so inclined, remove the rubber exhaust tube and use the camera through the actual exhaust exit.
The ones I take out of my 4.3 are usually a tad darker but without the deposits I see on the ground strap part.
This engine has the original block, so pistons, piston rings, etc are all original, I don't know how many hrs for sure it had before I got it, but I'd estimate between 1500-2000 hrs. Cyl heads I installed 10 years ago, so at least the valve seals aren't all that old.
nola mike
I tried to borescope it @Lou C but my access on the manifold is low on the side. Couldn't get it in enough to see anything, and not sure that I'm in the exhaust path or the water jacket.
