Re: Please help!!!
HOGWASH! Pistons are still available. Stock size 3.3125. You need to check the cylinders for damage to see if the block needs to be bored oversized. You can go .010, .020, and .030 over. In addition to Sierra, Vertex, and Merc, Wiseco sells pistons and they are easier to install than stock type. Forged, not cast, so they are stronger too.
Figure on about 125 per piston and 50-60 for boring each cylinder. Do the work yourself and you will save lots of money in labor. maintain the engine yourself and it won't cost much to keep it running. Abuse it and yes, you will always be putting money into it.
