Please help
toonin22
I have a 96 gamefisher 5hp which was made by force. The carburator is pouring fuel out. The engine is not responding to the throttle. It just revs up and then goes right back down. Any help or a point in the right direction will be greatly appreciated.
jerryjerry05
Re: Please help
Sounds like the needle and float are stuck.The main jet is probably clogged too..
Take the float bowl off and CLEAN all the stuff in there.Make sure you use only WD-40 or something like that to clean.Other cleaners can ruin the seat/seals.J
