Charles Bush
- Aug 9, 2006
- 21
have a 86' Renken 3.0 I/O with OMC outdrive, changed solenoids x 2, changed tilt motor, pulled clutch pack (no water) cleaned and rebuilt according to book, tested without clutch pack in and it spins fine, put new nylon washer on worm gear shaft, new o rings and gasket (shim) put back together, adjusted with allen wrench until clutch cant be spun by hand, (cant find the instructions for final tension adjustment) oiled, and it just clicks at clutch, took off brass gear on outboard, and the clutch unit spins nicely, put back on gear and click at clutch.
