I'm looking to buy a used boat and came across an '85 Sea Ray Seville (19'). It has a 170hp 4-cylinder (Chevy I think) and a MerCruiser. I was initially attracted to this boat because it has only 64 hours on the engine (according to the meter) and has fresh-water cooling; however, the boat has been sitting since 1997. The interior/upholstery is rough from sitting; but the engine looks very clean. The owner bought it in 1990 and used it four times before he got sick; he passed away last year and his wife now sells it without knowing much about it. Supposedly, the owner did winterize it before he stopped using it.<br /><br />Needless to say the engine doesn't start right now. Thinking that I could revive it, I verbally agreed to buy it; but now I have cold feet. I wonder whether its low hours is negated by the fact that it sat for so long. Is there much harm done to a boat engine when it sits for so long? What things could go wrong? Is a low-hour engine that sits worse than an often-used one that's maintained?<br /><br />I'm not an expert mechanic or anything but I've had experience working on my cars and an old outboard. Would it be worth the risk to buy this boat at a cheap price?<br /><br />I hooked up a discharged battery to it and put a charger on "Engine Start" mode and tried to crank it. I only hear clicks from the starter but no turning. I'm hoping it's because there's not much juice in the battery. I plan to spend a morning trying to get it to start before I decide. Can you suggest what prep work I need to do? From other posts in this forum, I gathered that I should do things like <br />- put Marvel Mystery or WD40 in the cylinders<br />- lube the impeller (if I can find it)<br />- check for spark<br />- OTHER?<br /><br />Any help would be appreciated. I'd hate to back out but I don't want to be getting myself into a nightmare either. Thanks in advance.<br /><br />tuan
