Please help..which thermostat?
Bass-by-you
While plundering around my project I have discovered that the GM 5.0 does not have a thermostat. 25 ft. cuddy with Alpha I..Can anybody tell me what temp thermo I need. Think this engine is about an '84.
Thanks guys!
ErieRon
Re: Please help..which thermostat?
Ideally, you would find the serial number of the engine so the year and model can be confirmed. Then, someone here, or any Mercruiser dealer could tell you. The serial number is often on a tag on the block just in front of the starter. The factory manuals are also available in the "Adults Only" section at the top of the main page where you posted.
Bass-by-you
Thanks for the tip......I'll get it in the A.M. and get back here.....this place is great and I really appreciate all the help I get here.
Bass-by-you
Okay............after hanging upside down in the bilge while holding a flashlight with one hand and pushing some hoses out of the way with the other hand, I came up with this serial number: 6812223 Will this get me the thermostat info?
Many thanks guys
ErieRon
Bass-by-you
ErieRon...thanks. There is a cover over the top of the 2BBl carb with the 898 label on it also something about thunderbolt ignition....anyway, thanks agian. I will order the parts right here.
ErieRon
You're welcome.
So, next time you post, include all that info. about your engine, eh.
Good luck & happy boating.
