Majick
- Mar 18, 2010
- 11
I have a 1988 Mercruiser 5.0. Last weekend I went out and when coming in the starter started spinning. When I removed the exhaust manifold to replace the starter I noticed they were old, rusted and corroded. I then took out the spark plugs and on the starboard side water came out of the spark plugs.
I replaced the starter, exhaust manifolds and risers and spark plugs.
After replacing all of the above the motor started and ran. I shut it off and went to restart the motor again and I could tell the same thing was happening. I removed the spark plugs again and on the starboard side the plugs have water again.
No water is in the oil.
Any suggestions?? The only other thing I can think would cause this would be if the block was cracked but there is no water in the oil so I am stumped.
