i have a 1990 four winns freedom 195 with a 4.3 OMC. couple weekends ago i got caught up in some kelp beds just off point loma, ca., the kelp blocked off my water intake on the lower unit and subsequently ate up my impeller. ive ordered a replacemnt water pump impeller kit including a new housing and water pump adapter. my question is this: if your standing behind the boat looking forward at the outdrive on the left side of the outdrive and just left of the water pump assy there is a drain plug with a chrome finish. i removed that drain plug so i could remove as much sea water as possible and when i took it out i noticed that the nut behind the plug dropped down into that water cavity. i fished for hours with a magnet trying to retrieve it but cant seem to find it. first question is why did they put a nut back there instead of some type of nut insert and 2nd question if i cant retrieve it will it damage anything to leave it in there? im trying to avoid tearing down the outdrive to get it. PLEASE TELL ME HOW I CAN GET THIS NUT OUTTA THERE WITHOUT COMPLETE DISASSEMBLY! thanks
