I have a 1996 mercury 150 2 stroke oil injected carb outboard. So i know for sure my enricher/choke valve is bad as my motor is really hard to start cold and I have to tilt motor back to start. I also took multi meter to it and have power when pushing in key but no click. Once warmed up it starts perfect when hot. Last few times I took it out without replacing the enricher thinking that its ok for now but ive been having another issue. Last time out, boat had no power and would not get on plane. Started fine and idles ok but no power at wot. So i pulled the plugs and they looked fouled so I cleaned them off with sandpaper and boat got right up on plane. Unfortunately after sitting on anchor for awhile and going back to launch ramp same problem. No power at wot.
So im thinking time for plugs again but is the enricher valve causing my plugs to foul out or should I be looking somewhere else like oil injection or? Any advive as where to start?
Thanks
Thanks
