Please help me!!
chdabren
I have an '84 (I believe) Honda 7.5 hp, 4 stroke outboard, model # BF75S. It won't start (has fuel and spark altho spark is not as strong as I'd like, no big fat blue spark) and I'm not sure if it's ignition box related or perhaps a bad ground. It does have a timing belt on it and I think the timing may also be off but I do not know where the alignment marks are supposed to line up. Does anyone know where I can find the alignment marks online? I have a dot on the cam sprocket that I've lined up with what looks like another dot on the head but when I spin the motor over by hand, I'm getting fuel dumping out of the spark plug hole (plug removed from head). I'm sure it's out of time but I've no way to verify timing mark location. Does this motor use "points" type ignition or electronic (c.d.i. box)? Please if anyone can help me with links, information or anything at all, I'd really appreciate it!! Thanks
Chris
JUSTINTIME
Re: Please help me!!
could be points or fuel pump
fuel pump is nla from honda
shoot me an email for a factory manual
chdabren
Hi Justintime...........I've got plenty of fuel...not a problem there. Just looks like proper spark is lacking. I do have some spark....just not enuf to lite the mix. And when I turn it over (plugs removed), it's dumping fuel out the plug holes like timing is off. My email is .....chdabren@yahoo.com. Mainly I want to make sure it's in time and I need locations and specs on timing marks to make sure of that. Thanks in advance for any/all help!
Chris
