get to the impellar shaft in a XL 700 waverunner? It is not turning and I need to see if the shaft is bent or the impellar is damaged. Please help!:redface:
your problem is common,, the pump liner has swelled from corrosion under it,, it has locked up the impeller,, you will need a new pump section where the liner is,and possibly a new impeller
