Please help head tourqe spec
Painterx
Hello,I'm looking for head and water cover tourqe specs for a johnson 1983 (j150tlcte) I bought everything new stats,water deflectors,gaskets,service manual.well everything showed up today except the service manual and would like to get this thing back and running by the weekend.please if anyone can help it would be great.its been down for the past 3weeks.I also bought some omc gasket sealer but it looks brown and very liquidey should I use it or not.
Joe Reeves
Re: Please help head tourqe spec
If you have the latest head gaskets, you will no doubt notice that they appear shiny. If so, look closely and you may see that at some area on the gasket, it states "use no sealer". The shiny stuff is a sealer that seals with heat.
If you have the older type gaskets, simply coat the gasket with oil... nothing more.
The bolt torque is 18 to 20 foot pounds, to be tightened in the following sequence:
13..14
9....10
5.....6
1.....2
4.....3
8.....7
12...11
This may be of some interest to you:
(Gasket Sealers)
(Usually available at any reliable automotive parts type store)
(J. Reeves)
Do Not use any type of sealer on outboard carburetor or intake manifold gaskets as this would cause blockage of various fuel/air passageways. Also, there are new type gaskets, including head gaskets, which are used through out the engines that are coated with a substance that gives a shinny appearance to them. These gaskets are coated with a self sealer and are to be installed as is.... no sealers! Older style head and fuel related gaskets that are not coated with this substance are to be simply coated with oil.... nothing else.
All other gaskets (hopefully I've not overlooked anything above) should be coated with Gasket Sealer (the type that comes in a can that has a small brush in its screw off cap). This also pertains to some water pump installations that use a gasket between the plate and the lower unit housing.
Marprox Sealer 1000 or OMC Adhesive or Boat Armor Sealer 1000 (same substance)[See Below Note] should be used on any metal to metal (Unless GelSeal Is Called For) or metal to plastic surface (such as impeller hsg to plate, and plate to lower unit surface) to eliminate air leaks. It should also be used on the Spaghetti tubing that is used on many powerhead crankcase halves, lower unit skegs, etc. I have found that this substance works quite well on various "O" Rings such as what are found on lower unit carrier and upper driveshaft bearing housings (Note that this substance is obviously not to be used on all "O" Rings). This substance also works quite well in sealing the surfaces between the lower unit and the exhaust housing to which it attaches, eliminating the unsightly water spray between the two after completing a water pump installation.
NOTE 1: I am under the impression that Marprox Sealer 1000 and Boat Armor Sealer 1000 is no longer available.
NOTE 2: OMC Adhesive is now Bombardier 3M Product #847 .
DO NOT use any sealer on the large "O" Rings that are used on the upper and lower crankcase heads (The housing/heads that slide over the top and bottom of the crankshaft). On those "O" Rings, use only a coating of grease.
The exception of surface to surface contacts pertains to the later model matching crankcase (block) halves (which does not incorporate spaghetti tubing) which call for "Gel-Seal", or any other surface that calls for Gel-Seal. This substance seals in the absence of air, and if called for, must be used. One other form of Gel Seal that can be substituted is "Loctite #518". Nothing else that I know of will do!
I advise against using silicone or permatex on a outboard engine. It simply will not function properly. The exception to this (as per OMC's recommendation), is to use the black Permatex (heavily) on the gasket 306242 which seperates the inner exhaust tube from the exhaust housing on the 1959 35hp and 1960 to 1970 40hp OMC outboards.
itsaboattime
Head bolts for your motor get torqued to 18-20 ft-lb.
Here is the torque sequence.
Remember to re-torque these after(I think) 2 hours of run time.
