alaskanassassin
- May 19, 2010
- 61
I had a bad start to my boating season. My 2004 mercury 200hp carbed v6 blew an impeller and no overheat alarm. I heated it up enough to melt the insulation on a wire touching one of the heads. I replaced the impeller and housing and ran it. It runs great until it warms up, then the idle slowly drops until it quits. I restarted it and it runs fine for a minute but only with my idle lever up a ways, then rpms drop, etc. When I pulled it back on the trailer and dropped the motor down, lots of oil (mix, not gear oil) came out the center of the prop. I pulled each spark plug and looked at pistons, and they are all the same color, pretty dark. I will do a compression test tomorrow, but the engine seems to run good and quiet. Is this a sign of a bad head gasket? How bad could it be? I am pretty mechanically inclined, Is this a huge expensive p.i.t.a. job? I will order a service manual on Monday, does the dealer carry this? I would have to pull the engine and ship it to get it worked on, I live on an island with no Merc. dealer so I am trying to avoid this. If you have any ideas, please let me know. Thanks for the help-AA
