bluebear57
- Mar 12, 2011
- 76
I had a thermostat quit working in my 89 150 mariner large compression number two cylinder ran great would not idle took motor apart reboard installed new piston put back together and would not run properly first no spark jet put on new stater then would start run rough and idle out of control ended up putting two CDI packs on rectifier and new stater starts in the driveway with muffs put it in the water will start won’t idle or idle is it 3500 RPMs even when you put it back into neutral I have no idea what else could cause that to do that I’ve been on this project four months and when I had the money.Any ideas would be greatly appreciated don’t understand how a motor give me a put into neutral and still rev 3500 RPMs and when it does start and idle normally you put it in gear and you got no power and it dies thank you very much
