wheresthefish
- Feb 28, 2007
- 61
i am trying to remove the block from the motor. i removed the six bolts under the block on the exterior of the motor housing and the nuts that have the rubber bushings on the inside of the motor cover. i cant see any other bolts or nuts on the inside or outside of the motor, except the two screws on each side of the shaft where i removed the six screws. how do i get the block off the motor body?
