Please help.85HP Johnson 1969
bigbadjim
:confused:So I've come across a problem and dont know why this is happening. I have hooked the clip of my test light to the positive starter post and then touch all the terminals on the terminal block. All of them light the test light except the one that is directly to battery. All switched terminals on the block light the test light Why is ground feeding through the teminal block. It is blocking the coil from working. Any help wouuld be greatful
Daviet
Re: Please help.85HP Johnson 1969
Might need a manual to check the electrical system.
