I have a 1984 Mercruiser 4 cylinder
Alpha 1
Rack & pinion power steering
I am in Fl and use often., but between trips boat could sit a week or more... Get into boat, move steering, extremely tight almost too the point of locked but after a number of hard turns on wheel frees itself and steers okay all day. Sometimes steering is harder then other times, but attributed this too cable .
Other day it totally locked up. After a hour of messing around trying too free, greasing like crazy nothing,
TIME TOO CHANGE CABLE
On forums, You Tube, and other sources tells you, does not really show you , how too remove, bang, twist, destroy your boat,
But still does not show how cable comes out of tube
My goal is too remove entire housing with cable from helm too stern. Grease, install new cable , then re- install
THIS IS WHAT I HAVE DONE SO FAR
Removed coupling
Opened large bolt that held cable too steering tube
removed clevis pin and was able too pull tube which freed it self from assembly
unbolted that long threaded steering tube from adaptor
Loosened Bolt that holds adaptor, thinking I can removed all the cable with housing, but must be stripped, just turning but not separating from power steering ?
Everything is loose
I am confused, never doing this , Do not want too bang, twist, destroy, just want too remove cable from boat .
Is cable supposed too come out of tube ?? Is it attached inside of tube?
Am I going about this all backwards , wrong?
Does the cable start at back end?? How is cable secured into that tube , that nut ??
Is circle at end the starting point, and that stainless nut holds cable
Going into cabin wanted too see the other end
Goes into rack & pinion steering bar
Two nuts and bolts holding cable
Tried loosing jam nut and it spun twisting back .
Walked away, looks better in morning, and maybe somebody in this forum and say, its easy, your almost there, ???
thanks guys
Alpha 1
Removed coupling
Everything is loose
thanks guys
