Re: Please explain fuel system/pump 50hp Evinrude.
when you go to start the motor, when you pump the bulb, this moves gas thru the lines,thru the fuel pump, to the carbs, and primer. this is the only function of the bulb. the fuel pump works off the vacuum, of the cylinder, via a diaphram in the pump, and draws gas from the tank, and pressurizes it to the carbs, and primer. there is no electric pump, the needle float valves in the carbs, allows fuel to flow into the bowls, when the bowl is full the valve stops the flow, until part of the fuel is used up, then it replenishes the supply, just like a toilet float in the tank. the primer is and electric solenoid, that allow pressurized fuel to the sprayed into the back of the carb, directly into the intake for the cylinders, it is also known as and enricher, the reason that it enriches the fuel mixture (more fuel to air) the purpose is cold engine starting. once the engine is running the carbs take care of the fuel mixture. they primer serves the same function as the choke on older motors. when the choke butterflies were closed, they was little air entering the carb, so the pistons pull in mostly gas, and enrichened mixture. there is a set of reed valves behind the carbs, if these are dirty, varnished, or distorted, they can effect the running of the engine. that the basis of the fuel system.
you can go to this site, and see the complete breakdown of you engine, parts diagrams,and list. "http://www.evinrude.com/en-US/Accessories/Literature/"
post a picture of the fuel pump the person added, it could be the wrong one, or misinstalled.
