Re: platinum spark plugs for outboards ?
Can't see why they'd burn hotter. Heat range adjusts for temp...<br />The whole benefit behind platinum plugs is longevity. Because of the nature of deposits in a 2-stroke, you'd be better off changing them more often, than trying to reap the benefits of a platinum.<br />A down fall with platinum plugs is that they do last longer, and when left in an engine(especially aluminum head) for a long interval, tend to take threads out with them because of the long marriage with the metals. <br />Plugs like V-groove and I believe split fire, get their claim to fame by providing a large sharp area for the arc to travel from. As time goes on, the sharp areas errode, requiring more voltage to jump the gap, so these plugs supposedly last longer. Again, your plugs should be changed long before this takes place. <br />Most of the snake oil plugs out there are for marketing purposes.<br /><br />In my opinion, for what its worth, change plugs often(keeping deposits low and threads happy), use OEM recommended plugs in most cases and don't waste money....<br /><br />my .01 cents worth
good luck!
