Plastic gas tank ok to use?
The Wright Stuff
I just bought my first boat a few weeks ago. It has a plastic gas tank. Is this safe/ok to use or should I get a metal tank? Thanks
marinemech1
Re: Plastic gas tank ok to use?
should be ok as long as its c.s.a. or u.l. approved
timfromfc
It should definitely say that it is approved for gasoline, otherwise it is against the law. I'm not even sure you can buy metal ones any more. All the ones at the marina I go to are plastic.
roscoe
Metal 6 gallon tanks are available, $100 -$140<br /><br />Plastic, $25-35.<br /><br />Take your pick.
The Wright Stuff
aahh, ok. I had always seen the metal tanks before so was kind of thrown when I saw the plastic one. Thanks for the help as always.
khc1970
On small trailer boat over here, the majority (over 90%) of us use plastic Quicksilver (type). <br />Being a trailer boat, we usually take the tank to the garage and fill up with petrol and take it back on board. The number of trips means after a while the bottom of metal tank are scratched and starts to rust and it will mark the grp.
