Pivot shaft seal
tuandabrainz
I am rebuilding a 1990 Renken with twin 200 HP extra long shafts. While adjusting the shift linkage height, I noticed the pivot shaft seal where the linkage goes up through the midsection is bad. I cannot find any how to videos on how to change it. Any suggestions on where to get instructions? What does this particular seal do? Can I run without replacing it?
Rustywrench
If you are talking about these seals here you should be OK with frequent greasing of the swivel bracket. Not abnormal to see grease coming from this area. Salt water motors could be tough to change? Fear of broken bolts.
Reference #4.
imagegif
tuandabrainz
Rustywrench If you posted a drawing or photo It is not visible in the post. I am talking about the thick rubber cylinder inside a cap that is at the bottom of the mid section, right above the entry hole the linkage comes up through. I don't see why it would really be needed as the bottom of the linkage and the rest of the lower unit are watertight. I really don't want to take this assembly apart because I am positive galvanic action would make it impossible to take it apart without breakage
Rustywrench
Sorry the photo didn't come thru. Part #320937 on a parts break down. Reference #4. Yes, I agree with you. Just keep the swivel bracket full of grease so salt water corrosion doesn't bring your steering to a halt. The steering arm moves inside the swivel bracket.
