Re: Pitted impeller
I've been hoping some one with expertize in impellers would come along.
I'm certainly not an expert. But to me if the impeller is pitted it most likely is worn enough to replace it. Time to bite the bullet. Regular props that aren't exposed to the pressures of an impeller wear out.Your is most likely worn out
especially if you run in clouded water.
